Hi, thank you for the reply.
@RPTHOMAS108 wrote:
It is telling you that the column in the type catalogue doesn't have a compatible parameter in the Family. So you should check the family has the parameter of same name and type for each of the columns in the type catalogue.
This is the Autodesk's content package - I didn't edit no content - am I the only one having this issue?
Is anyone who is working with a Content Pack other than the original installation language supposed to edit every family's txt file to modify the attributes?
This is frustrating and time-consuming.
When I open the family in Revit, it has English naming, while the .txt file has German naming.
Same content package.
I assume that Revit automatically translates the parameter names from RFA, while the TXT naming remains untranslated.
I can't see the logic. Especially when I encounter other RVA families that have parameter names that are NOT translated.
That being said, I have translated
,Breite##SECTION_PROPERTY##MILLIMETERS,Höhe##SECTION_PROPERTY##MILLIMETERS,Flanschdicke##SECTION_PROPERTY##MILLIMETERS,Stegdicke##SECTION_PROPERTY##MILLIMETERS,Stegabrundung##SECTION_PROPERTY##MILLIMETERS,Querschnittsfläche##SECTION_AREA##SQUARE_CENTIMETERS,Umfang##SURFACE_AREA##SQUARE_METERS_PER_METER,Nominalgewicht##WEIGHT_PER_UNIT_LENGTH##KILOGRAMS_FORCE_PER_METER,Trägheitsmoment starke Achse##MOMENT_OF_INERTIA##CENTIMETERS_TO_THE_FOURTH_POWER,Trägheitsmoment schwache Achse##MOMENT_OF_INERTIA##CENTIMETERS_TO_THE_FOURTH_POWER,Elastizitätsmodul starke Achse##SECTION_MODULUS##CUBIC_CENTIMETERS,Elastizitätsmodul schwache Achse##SECTION_MODULUS##CUBIC_CENTIMETERS,Plastizitätsmodul starke Achse##SECTION_MODULUS##CUBIC_CENTIMETERS,Plastizitätsmodul schwache Achse##SECTION_MODULUS##CUBIC_CENTIMETERS,Schnittnamenschlüssel##other##,Typenkommentare##other##
to
,Width##SECTION_PROPERTY##MILLIMETERS,Height##SECTION_PROPERTY##MILLIMETERS,Flange Thickness##SECTION_PROPERTY##MILLIMETERS,Web Thickness##SECTION_PROPERTY##MILLIMETERS,Web Fillet##SECTION_PROPERTY##MILLIMETERS,Section Area##SECTION_AREA##SQUARE_CENTIMETERS,Perimeter##SURFACE_AREA##SQUARE_METERS_PER_METER SECTION_MODULUS##Nominal Weight##WEIGHT_PER_UNIT_LENGTH##KILOGRAMS_FORCE_PER_METER,Moment of Inertia strong axis##MOMENT_OF_INERTIA##CENTIMETERS_TO_THE_FOURTH_POWER,Moment of Inertia weak axis##MOMENT_OF_INERTIA##CENTIMETERS_TO_THE_FOURTH_POWER,Elastic Modulus strong axis##SECTION_MODULUS##CUBIC_CENTIMETERS,Elastic Modulus weak axis##SECTION_MODULUS##CUBIC_CENTIMETERS,Plastic Modulus strong axis##SECTION_MODULUS##CUBIC_CENTIMETERS,Plastic Modulus weak axis##SECTION_MODULUS##CUBIC_CENTIMETERS,Key Section Name##Other##,Type Comments ##Other##
I had to paste both lines along with values for default (HEB260) column in the same text editor, and then to color one by one parameter along with values, at the same time looking at the family opened in Revit to be sure that generic translates were accurate (as they weren't).
I have managed to alter the generic translation to represent the Revit's naming, except the (not so important) "Schnittnamenschlüssel". As I couldn't find the name in the Revit, I have named it "Key Section Name", and got the "The parameter Key Section Name doesn't exist in the Family. It will be ignored." warning.
Bottom line: Am I supposed to do the same for every family from "German Content Pack" as long as I work in English installed Revit?
There has to be a logical solution. I just refuse to believe that such a huge company like Autodesk has such a work philosophy.
What will happen if we get the project in Italy? I am afraid to mention Japan, China, Korea...?
