Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Level in supresion 0' in elevation tag
7 REPLIES 7
Message 1 of 8
1726 Views, 7 Replies
I have an small issue that idon't know how to resolve. Level tag is not showing feet, (0" instead of of 0'-0"). Any level over one foot it will show correct (See image) Any help will be appreciated. Thank you
Window 7 Pro
Revit 2016
Tags (1)
7 REPLIES 7
Message 2 of 8
ennujozlagam
@Anonymous can you share that level in a file and post here? thanks
Message 3 of 8
in reply to: ennujozlagam
Thank you ennujozlagam for your reply. There you go.
Message 4 of 8
A_MAQ
Hi @Anonymous,
this is will be performed , because revit does not show less than 1 feet
Autodesk Expert Elite
Message 5 of 8
Untick Suppress 0 feet in the Elevation label in your Level symbol family, or change it to "Use project settings".
Message 6 of 8
in reply to: ToanDN
Thank you for all reply.
The Suppress 0 feet setting was already unstuck and I changed the setting to Use project setting without success. Any other idea why is this happening?
Message 7 of 8
shefypattambi
Hii,
not familiar with imperial unit system. But what are the other options you have in the Rounding - Nearest 1/4". try the smallest one.
Message 8 of 8
@Anonymous
Did you see the Revit file I revised? Make sure you edit the correct symbol because there are quite a few in your file.
