I have an small issue that idon't know how to resolve. Level tag is not showing feet, (0" instead of of 0'-0"). Any level over one foot it will show correct (See image) Any help will be appreciated. Thank you
Window 7 Pro
Revit 2016
Solved by ToanDN. Go to Solution.
@Anonymous can you share that level in a file and post here? thanks
Hi @Anonymous,
this is will be performed , because revit does not show less than 1 feet
Untick Suppress 0 feet in the Elevation label in your Level symbol family, or change it to "Use project settings".
Thank you for all reply.
The Suppress 0 feet setting was already unstuck and I changed the setting to Use project setting without success. Any other idea why is this happening?
Hii,
not familiar with imperial unit system. But what are the other options you have in the Rounding - Nearest 1/4". try the smallest one.
