hi everyone!
I have the next issue:
I've defined the export layer on reinforcement bars
then I have checked the thickness.
finally when I did the exportation, the layer of this reinforcement bar is ok.
but if I check the thickness of this layer in autocad, the thickness doesn't have any relationship with the thickness defined in Revit.
please help.
I got a client that gives us the layer that we must use in his project.
Solved by pendean. Go to Solution.
