Is there a final answer as to if Analytical elements can be exported to IFC?
- Mute
- Permalink
- Report
Why we need it:
Depending on material type, our engineers use 4 different structural analysis programs, all of which conveniently allow IFC imports. The REVIT 2020 docs state that REVIT has fully certified IFC import and export capability and I have found no contradictory information to that. However, nor have we been success in exporting the analytical model or finding an example online of this workflow.
In preparation for exporting the analytical IFC model we have done the following:
- Upgraded REVIT 2020 to be fully current as of today's date.
- Downloaded and installed the latest IFC2020 Add on from Autodesk.
- Created a project view (one in plan and one in 3D each for testing) with only the Analytical elements visible.
- Have an IFC config file where the analytical elements are exported as either ifcSlab, ifcFloor, ifcWall etc. or also "ifcBuildingElementProxy".
- Searched and searched and searched for a solution.
- Tried different configurations of the export options for weeks.
Required Outcome:
We'd like the analytical planes, lines, and nodes to be visible in Solibri Anywhere as a start. If anyone has any links to this workflow or a solution, please post it here. If someone knows for a fact this is not possible in REVIT, that would be useful too so that we can move past this hurdle and investigate other options.
