How to rebar fillet wall
daniel_compel
daniel_compel
Hi Forum,
I would like to ask for help. I think I kinda know my way around rebar in revit, but recently I came across this really basic need for reinforcement and it surprised me how difficult this is for me.
I want to create put rebar like red line in following picture in wall consisting of 3 parts (divided by green lines). I can do 3 separate parts of rebar (straight - bend - straight), but thats not good. Can someone help me please?
PS: Freeform rebar didnt work.
Dan.
EdwinG
Free Form Rebar is the way to do it.
Select Host surface (multiple)Select Host surface (multiple)Select pathSelect pathfreeform 3.jpg
daniel_compel
Thanks for quick response. I have a question, ability to control extension (length) is only by constrains in the cas of use freeform rebar?
EdwinG
yes i believe that is the only way
ovidiu_paunescu
Indeed, editing the bar constraints is the way to adjust the bar geometry.
You can also trim or extend the bars to other structural elements, including additional geometry, in case shortening all bars by the same offset doesn't produce the expected results.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
