Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Improve smlx import from Advance Steel
0 REPLIES 0
Message 1 of 1
Lorenzo.Taccini.STA
58 Views, 0 Replies
Ok AS is in maintenance mode, but it's still the software to use for accurate steel detailing and fabrication (welds, numbering, cladding, fabrication documentation, stairs, railings, ...) so please improve model import from AS to RVT. Some cuts, slotted holes, single bolts, bent profiles, ...  don't pass.
Also please merge some settings and resources related to steel (sections, materials, bolts, finishing, ...). Having to set twice same parameters with matching names and then manually associate them is nonsense.
0 REPLIES 0
Forma Design Contest
