Ok AS is in maintenance mode, but it's still the software to use for accurate steel detailing and fabrication (welds, numbering, cladding, fabrication documentation, stairs, railings, ...) so please improve model import from AS to RVT. Some cuts, slotted holes, single bolts, bent profiles, ... don't pass.
Also please merge some settings and resources related to steel (sections, materials, bolts, finishing, ...). Having to set twice same parameters with matching names and then manually associate them is nonsense.
