Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Importing navisworks model into revit loses colors and textures
18 REPLIES 18
Message 1 of 19
chriskD6WP2
704 Views, 18 Replies
I have a Naviworks file with an NWD extension I would like to import in Revit but whenever I insert it as a coordination model, I lose all of it's color and textures.
I have looked at the visibility graphics settings and can't see anything that would not allow color.
Attached is the Navisworks model.
18 REPLIES 18
Message 2 of 19
in reply to: chriskD6WP2
Is it from a point cloud?  If so, try to link the source point cloud file instead.
Message 3 of 19
chriskD6WP2
I'm trying to avoid using the point cloud. Witin ReCap, I used the mess creator and it gave me a color NWD file as one of the creations. I thought I could use it instead of the point cloud making it easier and quicker to navigate within Revit.
Message 4 of 19
Which file formats can you save the mesh to?
Message 5 of 19
chriskD6WP2
It says output can be OBJ and/or RCM. I click both and when it's done, I get a the OBJ and RCM as well as an NWD.
Message 6 of 19
chriskD6WP2
Sorry, I was wrong. I get an NWC as one of the files, not NWD.
Message 7 of 19
Export the mesh to OBJ and import it in Revit as an in-place generic model family.
Message 8 of 19
chriskD6WP2
Don't I have to have a plug-in to import OBJ files?
Message 9 of 19
Revit an import OBJ files natively.  See my screenshot above.
Message 10 of 19
chriskD6WP2
Looks like your screenshot is only showing partial content. I don't see a menu in Revit which looks like that image. I'm using 2021, sorry.
Message 11 of 19
Revit 2022.  I don't know if Revit 2021 can import OBJ.
Message 12 of 19
chriskD6WP2
No, it does not. Thanks anyway.
Message 13 of 19
chriskD6WP2
I did it in 2023 and the object still has no color. lol Oh, well.
Message 14 of 19
Can you share the OBJ file?
Message 15 of 19
chriskD6WP2
Here is the OBJ file.
Message 16 of 19
It shows here.
Message 17 of 19
chriskD6WP2
What?! Okay, let me see if I can load it into the generic out of the box construction template and see if that makes a difference. It may be something in our view templates that's not letting it load with color.
Message 18 of 19
chriskD6WP2
It's our view templates.
One more thing, is there a reason as to why you choose OBJ over an NWD?
Message 19 of 19
Because I knew OBJ should work and I can't say the same for NWD or NWC.
