Delete Rows
Delete Rows
dmaughan25
Message 1 of 19
Delete Rows
dmaughan25
The delete rows button is not working my schedule toolbar. I use to be able to select multiple rows and delete unused views, but when I push the button now, it does nothing.
Any suggestions?
Replies (18)
Message 2 of 19
ennujozlagam
try right click in your mouse and select delete rows and see if helps. thanks
Message 3 of 19
hmunsell
Do you get any errors when you select it or is it just not selectable? In your screen capture it looks "available". If you pick the Delete button in the bar below the ribbon does it do anything?
Howard Munsell
Message 4 of 19
dmaughan25
It gives me the option when I right click, but when I right click it does nothing.
Message 5 of 19
dmaughan25
It is selectable, but it doesn't do anything when I click it. If I right click and click the delete row button it also does nothing. It used to work, but sometime within the last few weeks it has stopped. It seems to be universal on any project that it is not working. I believe I have the latest hot fix installed.
Message 6 of 19
hmunsell
if you select only one row, vs multiple rows, does it work? trying to narrow down if it is something with the command or something with the item your removing.
Howard Munsell
Message 7 of 19
dmaughan25
Same result. One row vs multiple rows, Button and right click button are selectable but nothing happens when they are clicked.
Message 8 of 19
hmunsell
Hmmmm haven't personally seen that happen before. I have not been able to duplicate it on my end.
Would you be able to post your file, or a duplicate of the file with any project info scrubbed out?
Howard Munsell
Message 9 of 19
dmaughan25
Yeah I will try and get something posted this afternoon.
Message 10 of 19
dmaughan25
I started a blank template and added 4 drafting views and still getting the same result.
Message 11 of 19
ennujozlagam
i tried and managed to delete. try to install latest updates or repair the program and see if helps. thanks
Message 12 of 19
dmaughan25
What version of Revit are you running?
Message 13 of 19
ennujozlagam
here. thanks
Message 14 of 19
dmaughan25
I uninstalled Revit and reinstalled, but still have the same issue.
Message 15 of 19
dmaughan25
Does anyone have any other ideas on this? is anyone experiencing this bug?
Message 16 of 19
KANDERSONSAFDH
Observer
Observer
I also have the same issue with Revit 2021.  I can select rows, but delete row function does not work.  I have also reinstalled and maintained updates.  Also, had our BIM manager look into it and he couldn't figure it out either.
Message 17 of 19
dmaughan25
Yeah it has gone away for me, but no idea how it resolved itself.
Message 18 of 19
hmunsell
this might be a stretch.... but are any of the elements in the schedule coming from a Link? if you look at the schedules Fields tab, is the Include Elements in Links checked?
Howard Munsell
Message 19 of 19
jay_colcombe
The issue was similar in deception and said to have been resolved in an update but there are a couple of workarounds which may help?
Investigation of this incident determined that it occurs when all of these criteria are met:
  • In the Sheet List Properties, in the Sorting/Group tab, "Itemize every instance" is not selected.
  • In the Sheet List Properties, in the Appearance tab, Show Title is not selected.
  • In the Sheet List Properties, in the Appearance tab, Show Headers is not selected.
Workaround:Workaround Option 1: In the Sheet List Properties, in the Appearance tab, select Show Title, Show Headers, or both.
Workaround Option 2: In the Sheet List Properties, in the Sorting/Group tab, select "Itemize every instance." Then, to use a sheet list to delete sheets, select sheets in the list one at a time (or drag to select more than one adjacent sheet).
Incident ID:93390
Jay Colcombe
Autodesk Certified Instructor
