Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
IFC custom property NOT EXPORTING
4 REPLIES 4
JPNR87
277 Views, 4 Replies
HI,
I have problem with Revit 2025. Exporting IFC custom parameters set not working at all. What can cause this? Any ideas? Thanks!
4 REPLIES 4
jay_colcombe
in reply to: JPNR87
You can manually add them using this help article
Help | Certain parameters not exported to IFC from Revit | Autodesk
Jay Colcombe
Autodesk Certified Instructor
JPNR87
in reply to: JPNR87
Thank you for the answer, but following the instructions exactly as described in the help doesn't seem to work for me.
Have tested other possibilities but no success
JPNR87
in reply to: JPNR87
Can anyone identify from this short segment why the export of IFC custom properties isn’t working?
I’m not sure where the issue is
JPNR87
in reply to: JPNR87
Uninstalling Revit IFC 2025 plug in resolved an issue I was facing.  I have no idea what caused it. (https://up1.autodesk.com/2025/RVT/ADSKIFCExporterHelp_25_2.htm#Install)
