- Mute
- Permalink
- Report
HI,
I have problem with Revit 2025. Exporting IFC custom parameters set not working at all. What can cause this? Any ideas? Thanks!
Link copied
HI,
You can manually add them using this help article
Help | Certain parameters not exported to IFC from Revit | Autodesk
Thank you for the answer, but following the instructions exactly as described in the help doesn't seem to work for me.
Have tested other possibilities but no success
Can anyone identify from this short segment why the export of IFC custom properties isn’t working?
I’m not sure where the issue is
Uninstalling Revit IFC 2025 plug in resolved an issue I was facing. I have no idea what caused it. (https://up1.autodesk.com/2025/RVT/ADSKIFCExporterHelp_25_2.htm#Install)
