Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How to fix Slanted column-beam joint? (concrete)
4 REPLIES 4
roquealfonso
1622 Views, 4 Replies
How can I fix the joint of a slanted column and beam (concrete)? In some cases, it gets it right in some it doesn't.
1) For this joint, the beam section doesn't align with the slanted column:
2) In this joint, it's modeled properly:
Labels (3)
4 REPLIES 4
catalin_lang
in reply to: roquealfonso
I would try to switch join order (Modify tab> Geometry panel> Join drop-down list> Switch Join Order)
Can you attach a sample of your model? just the slanted column and the attached beams, both directions?
catalin.lang
roquealfonso
in reply to: catalin_lang
Here's a sample of the model, elements in (red) are the ones referenced in the pictures.
catalin_lang
UnJoin the beams. In corner areas, the perpendicular beams are by default joined, not the column and the beamcapture-1.gif
catalin.lang
roquealfonso
Thank You!
Forma Design Contest
