How can I fix the joint of a slanted column and beam (concrete)? In some cases, it gets it right in some it doesn't.
1) For this joint, the beam section doesn't align with the slanted column:
2) In this joint, it's modeled properly:
Solved by catalin_lang. Go to Solution.
I would try to switch join order (Modify tab> Geometry panel> Join drop-down list> Switch Join Order)
Can you attach a sample of your model? just the slanted column and the attached beams, both directions?
Here's a sample of the model, elements in (red) are the ones referenced in the pictures.
UnJoin the beams. In corner areas, the perpendicular beams are by default joined, not the column and the beam
