Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How to fix joist to column connection in 3d?
3 REPLIES 3
marc.khalil
300 Views, 3 Replies
I have a little problem: when I place roof joists in my plan they look like this:
Which look correct and match our standards. But in 3D they look like this
As you see, the joists and girders joint inside the column. How can I make the ends of joist and girders stop at face of column without affecting how they look in plan?
3 REPLIES 3
mphungDCHNW
in reply to: marc.khalil
You can drag the ends to the end face of the column or add a stop end point cut-off length at each end.
Change the Alignment Reference of Beam End Geometry in a Join
Help | Change the Alignment Reference of Beam End Geometry in a Join | Autodesk
marc.khalil
Thank you all for your suggestion.
@mphungDCHNW I tried to do that but it changes how the connection looks on the plan. Plus I had to do it for every single girder and joist. It was not working for me.
@barthbradley Thanks for pointing this function. When I tried it, It did nothing even after following the instructions in the link you posted.
I found an easier solution is to add few inches the Start Offset and End Offset. I can select multiple items and do this at once without changing how the plan looks.
Forma Design Contest
