Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Beam Connection Help
1 REPLY 1
caseyMG5WP
169 Views, 1 Reply
I have looked and searched for awhile now but can not find how to make a connection like I am needing to make. An engineer at work designed this small canopy. He calls the beam to column connection a cantilever connection. The structure is 4 columns with a beam that has a plate welded to it and then bolted to the column. I am not very experienced with Revit and no one else in my office is either. I have taken a class about Revit at my college but I have forgotten most of it. The book I have from the class doesn't really cover these types of drawings. The engineer that designed the structure has a Revit book, but it doesn't show connections like this. I would appreciate some guidance on this please.
1 REPLY 1
Karol_Piroska
in reply to: caseyMG5WP
Are you asking what connection should the engineer design or did he give you a sketch of the connection to use and you don't know how to model this in Revit? It would be a simple moment connection with an end plate and bolts or with added bottom haunch such as in portal frames.
