How to create precast Hollowcore floor
Message 1 of 24
I am using Revit 2018 and I want to design a precast Hollowcore floor.
I have downloaded the precast extension
but i couldn't find  a way how to create a new precast Hollowcore floor from scratch.
please help
best regards
Replies (23)
Message 21 of 24
WEC17
Something that you don't address is the importance is once copy and paste the file you have to right click the family and go to property and uncheck read only. Once you do this step you can save the family w/out any problem.
Another thing. I my case I am working on imperial and to make work I had to modify the template in "MM".  For ex. I made a 8" thick I had to convert to "MM" 203..2. this'd was the only way it would work.  Don't try changing the units in the template it will nor work. It will give an error on the width of the Hollo Core slab.
All my templates work once I did all this changes 8" to 203.2 mm, 10" to 254 mm, 12" to 304.8. what I am trying to say is the template need to be in "mm" in order to work in imperial.
Message 22 of 24
shuaib009
@teodorb
How can we have void of different shape, instead of circle in hollow core slab section?
Message 23 of 24
EdwinG
You have to create your own void type and load this one in to the Hollow Core Slab family.
This one has 2 different void's
Message 24 of 24
shuaib009
thanks @EdwinG . I will try this
