Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How do i create a slab which is extruded and has skewed ends?
3 REPLIES 3
nkosana.ndlovu
224 Views, 3 Replies
I am working on a slab which is sloped at 2.5% and has a profiled soffit. I would like to terminate the ends at a skew angle, but Revit will only allow me to keep it 90 degrees square to the extrusion. How can I terminate the extruded slab at a skew angle? Is there another way to create a skew slab with the desired characteristics?
nkosanandlovu_0-1705489124374.pngThe plan view has to be skewed.nkosanandlovu_1-1705489167494.png
The elevation is correct, but the plan needs to be "trimmed," or "cut," to make the skewed slab correct.
3 REPLIES 3
You would need to Create a Void Extrusion and you the Modify > Cut Tool Cut the Skewed Edges
Jay Colcombe
Autodesk Certified Instructor
Thank you. The solution is so elegant!
in reply to: nkosana.ndlovu
Use a vertical cut opening to cut it on the plan.
Forma Design Contest
