I am working on a slab which is sloped at 2.5% and has a profiled soffit. I would like to terminate the ends at a skew angle, but Revit will only allow me to keep it 90 degrees square to the extrusion. How can I terminate the extruded slab at a skew angle? Is there another way to create a skew slab with the desired characteristics?
The plan view has to be skewed.
The elevation is correct, but the plan needs to be "trimmed," or "cut," to make the skewed slab correct.
Solved by jay_colcombe. Go to Solution.
You would need to Create a Void Extrusion and you the Modify > Cut Tool Cut the Skewed Edges
