Help with wall constraints
The top constraint I just applied - "up to level 1" - should not be invalid for the level, as far as I can make out?
Level 0 = 0mm and Level 1 = 3600mm, There is no other element anywhere.
The default constraints on any level are always similar to this, i.e. -4000 base offset from level 0 to level 0 on level 0 floorplan, or -4000 base offset level 1 to level 1 if I am on the level 1 floorplan. I have created 3 new projects and even used a structural template but it is always the same problem.
And if I do manage to fix it for the singular wall I am placing, the default seems to be locked to the problematic version, it does not adopt what I've just told it to do as a new default.
As you may guess, I am a beginner.
Thank you for reading.
