Grids not appearing at the foundations level
Hello to everyone,
I am trying to export the foundation level from my Revit model into the AutoCad, but the issue that I am having at the moments is that the grids are not showing at this level. I think is due to the fact that the grid lines dont intersect this level, like it happen is the other levels, so I would like to know if someone know the solution to this problem. In the pictures that I am uploading you can see the blueprint of the foundations and also you can see the East view.
Best regards
twebb4CYQY
Typically yes, if you cannot see the grids in a plan but can in the remainder of your plans, it is because the grids are not intersecting that level.
I can see your grids in the full elevation clip you attached, best to check if that is 2D or 3D extents of grids.  It will be indicated when you select the grid.  3D extents are required to cut all the plans for visibility.
they all have the 3d extent... Througth the picture that I upload, in which you can see the east elevation, the grids all pass throught all the levels, wasn´t it supposed to show in all the levels?
Best regards
Avaris.
You do not have any view filters or a view template which hides the grid?
ennujozlagam
Hello, check your properties box if there is assigned view template, then set to none. Thanks
But i dont want to not have a view template...
