Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Framing Tag - Not Aligning to Modeled Element
10 REPLIES 10
Message 1 of 11
blesnau1
506 Views, 10 Replies
I'm currently working on a project where we model all 3D elements in one revit file, then add annotation in another Revit file with the modeled content linked into it.
Framing tags work just fine in some portions of the building, but for this particular view shown in the screenshot, the tag will not align to a diagonal or skewed beam.  Any ideas why the tag is behaving this way in this particular view?  Scope boxes are being used in all views.
10 REPLIES 10
Message 2 of 11
hmunsell
in reply to: blesnau1
Edit the family and make sure the Rotate with Component is checked.
Howard Munsell
Message 3 of 11
blesnau1
in reply to: hmunsell
It's checked... I don't think it's the family, because the tag works fine in other views with skewed beams.  It's just this particular view for some reason.
Can anyone think of a reason why a view would create this behavior of the tag?
Message 4 of 11
blesnau1
This can be ignored - The issue is resolved.
Message 5 of 11
hmunsell
don't leave us hanging... LOL.... What was the solution?
Howard Munsell
Message 6 of 11
blesnau1
Lol - I'm not entirely sure.  I deleted the view from the sheet, then placed it back on and everything was fine.  I think Revit just wants to pick a fight with us every once in a while.
Message 7 of 11
hmunsell
Ya.... that happens LOL.... Trying to keep us on our toe's.
Howard Munsell
Message 8 of 11
blesnau1
Ok this problem is still happening.  It was fixed, but now the tags all of a sudden won't align again.  It has something to do with the view... can anyone think of how a view would affect the tags behavior?
Again, this is a Revit file where we are tagging a linked file's elements.
Thanks!
Message 9 of 11
hmunsell
would you be able to upload the model for us to look at?
Howard Munsell
Message 10 of 11
blesnau1
Unfortunately I can't share a model.
Here's the fix though.  The views that are having this issue with the tags not working are dependent views of an Overall view (tags work just fine in the Overall).  For whatever reason, I have to open up the overall view, before I open up any other dependent views.  If any of the dependent views are not showing the tags properly, click on the tags in the overall view then go back to the dependent view and select all the tags, then escape.
Why this works is beyond me.  Seems like a glitch Revit needs to address.
Message 11 of 11
hmunsell
that is so odd.... never seen that as an issue. well at least you have a solution :-). mark yourself as the accepted solution for others to find too.
Howard Munsell
