Finding center of gravity
haydenwse
Message 1 of 78
haydenwse
In AutoCAD when I needed to find the center of gravity for a shape I would create a region of the shape and use the mass properties to find the C.G.  is there any way to find the center of gravity for a shape in Revit?
Replies (77)
Message 61 of 78
pboutany
Where do you get this COG:COG appear in family types from? I have no such thing.
Message 62 of 78
It should work with generic models "Solids" if it doesn't let me know but with regards to weight I could potentially have it use densities to calculate the CG when you have solids with different densities together. Is this what your asking for? It is possible so I will work on it and see where I get.
Daniel
Message 63 of 78
bradwitt
Daniel,
All of our custom families are generic models due to the flexibility we
need to do it that way. They are modeled as a solid, but the weight is the
most important factor for us. We have weights assigned to everything due to
crane operation lifting, and loads it applies to the floor slab. I was kind
of hoping that it could possibly work with the weights so we would not have
to do a lot of changes to our families.
Thank you,
Brad
Message 64 of 78
I see, would you be able to Dropbox me a model with these families in it? I would love to look further into it. It is definitely possible I just have to look at it.
Daniel
Message 65 of 78
Yes, this is what exactly I'm also looking for, calculate COG based on weight, it doesn't make sense if it calculates only based on mass
Message 66 of 78
bradwitt
Can you send me your email or something I can send you a file with weights in it?
Thank you,
Brad
Message 67 of 78
Dswanson@swansonlabs.co
Message 68 of 78
Hi Brad,
It would be great if I can get the dynamo script for weight.
my mail addres: venkateshvinod@tylin.com.sg
Message 69 of 78
Can you please share this script again. Dropbox link you provided is not active anymore.
Y0u can also just email it directly to ulebule@gmail.com
Thank you in advance!
Message 70 of 78
pboutany
Hi there, can do when I’m back in the office in the new week!
Message 71 of 78
haydenwse
I am the original poster on this tread and have been using an add-in from Swanson Labs called "CG Finder Revit Add-in" that has been working very well.  They are available on the AutoDesk App store for versions 2017 and newer.
Message 72 of 78
Thank you very much for sharing the CofG dynamo code.
I have been using it for a while now, however, sometimes it works and sometimes it gives me an error.
I mainly use it on generic models that I have modelled-up.
Please see image attached for the error.
" Warning: Internal error, please report: Dereferencing a non-pointer.Capture.png"
Message 73 of 78
Albert.Maduro
T H I S   I S   A W E S O M E ! ! !
Shoukran
Thank You
Salamat
Message 74 of 78
Albert.Maduro
Although the script is spectacularly awesome, it has its own limitation
1. It only calculates per element CG
2. It is not applicable for linked model
3. It leaves unselectable transparent yellow element
Message 75 of 78
velrajbecool
How you found center of gravity of model components in Autocad from Revit as there is no direct option to get COG in revit?
Please reply..
Message 76 of 78
dmooreUA7JK
Observer
Observer
Does anybody know if there's a 2021 version of the CG Finder mentioned in this thread? I've used the older versions and found it very useful but can't find a 2021 version.
Message 77 of 78
Evan.Pond
I'm looking to find the CG base on weights, I have multiple materials and equipment on a build that I need the CG.
Message 78 of 78
haydenwse
I did a search for where the cg finder was located and duplicated the whole folder to to the same place with the the name changed to C:\ProgramData\Autodesk\ApplicationPlugins\CG Finder 2021.bundle.
I then opened every file in the folder and did a "find / replace" to find every reference of "2020" and replaced it with "2021".
Works perfectly.
