Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Export IFC wall parts
2 REPLIES 2
GatisM
4623 Views, 2 Replies
Hi!
Is it possible to export from revit to ifc walls not with original geometry but with part geometry? Modeling precast walls but i need my project in ifc format too, any suggestions?
2 REPLIES 2
robert.klempau
in reply to: GatisM
Hello @GatisM,
See this article: Specify IFC Entities for Families
Install the alternative IFC Exporter from the Revit App Store.
Hope this brings you further.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
in reply to: GatisM
You should install first the IFC Exoirter App to have advanced export options.
You choose a 3D view and change the parameter "visibility of parts" to "show parts". [Now it should be possible to select the parts and apply specific parameters.]
In the IFC Export dialog, you have to select special options, otherwise the parts will not be exported (see screenshots)
