Revit-Sigma Integration Issues
Message 1 of 1
I've been having problems with the integration between Revit and Sigma Enterprise. I've been talking to Sigma support and they have decide that they can't help me, since they do not come across the same problems as i do when integrating with the same file as i have.
The problem is, that Revit stops functioning whenever i try to integrate. I'm pretty sure that its the connection between the two programs which is being blocked in some way. I've tried integrating on my friends computer with the same Revit and Sigma versions as i'm using with the same results...
Do anyone know if there is some kind of setting that you have to setup in Revit so that the connection isn't gonna get blocked ?
Or do anyone know of another solution to this problem!
Regards
Thomas Hagen.
Replies (0)
