Good morning .
I am trying to edit a concrete precast wall profile . with one panel I could do my 1/2 gap very good but when I come to my second gap will not allow me to do a 1/2 gap but just snaps to the closest line and throws an error.
Any Idea what i am doing wrong?
Solved by EdwinG. Go to Solution.
Solved by hvcprecast. Go to Solution.
I use the gap tool to create PC panels and it is tough to get the joint where you want it on the click. I just break that panels close to where I want them and then drive them to the correct dimension with a dimension string. The gap is locked to both panel edges will adjust.
The gap tool will split my whole wall , it actually won’t recognize that I want to jog half way down the wall , and that’s why I was asking for edit wall profile.
But i found my own solution , we have to very carful that all corners connect with each other , so when selecting a line type . instead of selecting a single line I selected a complete square line type and that solved my problem.
Thank you for your suggestion anyways.
I tried using the parts join tool but it really messed up the reinforcement. That was back in 2016 so maybe it is better now but I have not tried it again. (Now that you made me think about that project, the nightmares are going to start again, Dang it!)
not really my friend , I'm doing precast with Revit precast and no other precast paid addons and its very slick
That was what I was doing as well only it was the the version before AD bought the addon. I might need to try it again but have developed my own tools to do precast in revit.
