Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
editing a wall profile
8 REPLIES 8
Message 1 of 9
hvcprecast
609 Views, 8 Replies
Good morning .
I am trying to edit a concrete precast  wall profile . with one panel I could do my 1/2 gap very good but when I come to my second gap will not allow me to do a 1/2 gap but just snaps to the closest line and throws an error.
  Any Idea what i am doing wrong?
John
Labels (1)
8 REPLIES 8
Message 2 of 9
haydenwse
in reply to: hvcprecast
I use the gap tool to create PC panels and it is tough to get the joint where you want it on the click.  I just break that panels close to where I want them and then drive them to the correct dimension with a dimension string.  The gap is locked to both panel edges will adjust.
Message 3 of 9
hvcprecast
The gap tool will split my whole wall , it actually won’t recognize that I want to jog half way down the wall , and that’s why I was asking for edit wall profile.
But i found my own solution , we have to very carful that all corners connect with each other , so when selecting a line type . instead of selecting a single line I selected a complete square line type and that solved my problem.
  Thank you for your suggestion anyways.
John
Message 4 of 9
EdwinG
Maybe is parts something for you
See screencast
https://autode.sk/3iqbywm
Message 5 of 9
hvcprecast
Thank you , that will also work.
John
Message 6 of 9
haydenwse
I tried using the parts join tool but it really messed up the reinforcement.  That was back in 2016 so maybe it is better now but I have not tried it again.  (Now that you made me think about that project, the nightmares are going to start again, Dang it!)
Message 7 of 9
hvcprecast
not really my friend , I'm doing precast with Revit precast and no other precast paid addons and its very slick
John
Message 8 of 9
haydenwse
That was what I was doing as well only it was the the version before AD bought the addon.  I might need to try it again but have developed my own tools to do precast in revit.
Message 9 of 9
hvcprecast
would you mind sharing your tool
John
Forma Design Contest
Technology Administrators
