Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Dimension snap to linked model columns
14 REPLIES 14
Message 1 of 15
cillian
1880 Views, 14 Replies
I am having an issue where I have a linked IFC model in my Revit project. I want to add a dimension in a section view between a stairs (which is in my host model) and a column (which is in the linked model). Revit will not let me snap my dimension to any part of the column. I can add dimensions which snap to the linked beams without issue.
Labels (5)
14 REPLIES 14
Message 2 of 15
catalin_lang
in reply to: cillian
Can you add a small sample of your model (ifc linked included)?
Looks like an issue we recently addressed. I want to check if it's indeed the same issue and if our fix will solve it.
Thanks!
catalin.lang
Message 3 of 15
cillian
in reply to: catalin_lang
HI @catalin_lang ,
I have attached the host model (Structural) and the linked model (existing).
Message 4 of 15
ennujozlagam
you need to go properties > visibility graphics > Revit links > and set all basic/model categories/annotations categories > all to custom > then start your dimensioning and see if helps. thanks
Message 5 of 15
cillian
in reply to: ennujozlagam
Hi @ennujozlagam ,
I did as you said and changed all to custom (see screenshot) but I am still unable to snap dimensions to the linked .ifc file columns. So weird that it works fine for beams but not the columns.
Message 6 of 15
cillian
Hi @catalin_lang ,
Apologies I attached the wrong link file previously (Existing). Please see attached the correct link file which I am trying to snap dimensions to.
Message 7 of 15
ennujozlagam
opps . sorry i cannot open your file i dont have Revit 2021. thanks
Message 8 of 15
ennujozlagam
how about this select links should not be off or x. thanks
Message 9 of 15
cillian
HI @ennujozlagam ,
No, still not able to snap to columns in linked IFC file with select links option turned on or off.
Message 10 of 15
rkhattar
Might be a cut line / projection line issue.
Try setting you view to Wireframe Temporarily > Set the dimensions > Reset the view.
Hope this helps.
Message 11 of 15
cillian
in reply to: rkhattar
Hi @rkhattar
No luck snapping to column using your method either.
Message 12 of 15
catalin_lang
@cillian
Thanks for the model. Indeed, it is that issue that we'll address for the next release.
I could not say when it will be, but I'll try to keep you informed.
Thank you!
catalin.lang
Message 13 of 15
Hi Catalin,
Is there any solution to this matter since then?
In my case, I am trying to snap a point to put in a column on a revit link model but it doesnt work. I would appreciate your help .Thank you.
Message 14 of 15
reeya_patel_
Did this ever get an solution? I am having the same issue with a model sent to me by the steel fabricator I am having to export the steel to CAD then adding faint center lines then importing it back into revit to get the snap points to add dimensions. Surely the other end has a setting to add central axis lines? It's very annoying when I have to update their model in my drawing.
Message 15 of 15
pavlickDMY84
I'm having the same issue, not being able to dimension to a grid line in linked model.  I can dimension all day to all the other elements (walls, etc), but not the grid line.  Being that this is a new construction project, I have no choice but to use the grid/steel lines for reference.  Please help!
Forma Design Contest
