Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Creating unusual shaped wall
3 REPLIES 3
1624 Views, 3 Replies
How to create a wall (refer attached) I can create a slab to that shape but can i change the family type from slab to walls ?!!!
Thanks very much
3 REPLIES 3
Joe.Charpentier
That's what you want to see in plan view? Is that all one mass?
If so, make an in-place family.
If that's the elevation view, you need to edit the wall profile (though I have to admit that shape doesn't make much sense to me.)
Joe
Hello Joe,
Thanks for the reply...yes, that's a plan of a structural wall. The shape is an exaggerated version of what actually needed. Can I make a big column and chisel it to shape ?!!!
R
dmac7
create an in-place family of walls. Use solid extrusion and sketch your shape of the wall then finish sketch
Forma Design Contest
