Creating Filters that are based on shared parameters
Demetri.Ingilis
Message 1 of 11
Demetri.Ingilis
I am working on a project (Revit 2022) that has split the scope of work over 10 different packages. These packages are not necessarily done in a certain construction sequence. As some work in Package 2 would require some work in Package 4 to be performed, and vice versa. There are only two phases, existing and new construction. Therefore, in my plan and section views in one package, section callouts are visible that refer you to section views on other packages. We do not want to do that. What I used to do is just hide elements for the sections i didnt want to show in in certain views, but it gets really complicated when dealing with so many packages and would be nice if a filter could be created that would only display the sections on a specific package in a specific view. Here is the setup.
There is a demo view template, with filters locked to it.
There is a new construction view template with filters locked to it.
These two view templates would be constant to all packages to create some sort of visual uniformity between the different teams working on different packages.
I tried messing around with creating this view filter. Someone on my team created a shared parameter labeled "Package Number" which can be applied to sheets and views. I labeled all views in package 4 with the 4.00000 input. However, it seems the filter will only let me set this shared parameter equal to an input value, which would mean I have to create 10 filters- one for each package and would then have to either: 1- remove filters from the overall view templates (which forces me to now manually add back this new filter and all previous filters to each view), or 2- create a view template for each package, each with a different filter for the above issue (which will affect our want of uniformity between packages).
What I want is a filter to say, if shared parameter "Package Number" of a section view DOES NOT EQUAL the shared parameter "Package Number" of the view that it is in, then hide that specific section line.
Basically i want to link a parameter to another parameter in a filter, not link it to a set input value.
Any help would be appreciated. Thanks in advance.
Replies (10)
Message 2 of 11
RDAOU
@Demetri.Ingilis
You could do that with other means such as dynamo but not with view filters.
Shared parameter are intended for model elements/categories hence project parameters suffic. You can set condition "not equal to" or "does not contain" in case of sub packages; however, you would still need a filter for each package
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/filtering-sections-views-bas...
Message 3 of 11
Yes you can do that. You don't even need a shared parameter, just need a project parameter assigned to views category. The create filter for sections, elevations, call outs and apply to view templates.
Message 4 of 11
EdwinG
Message 5 of 11
See example file.
Message 6 of 11
Demetri.Ingilis
This is exactly what I am trying to avoid. I want one filter that can handle all the packages, not one filter for package 1, another for package 2, etc. This ruins my use of one view template for the entire project.
Message 7 of 11
- Create a view template for each package and uncheck everything except V/G Overrides Filters and apply them to your views per package
- Reversely, uncheck V/G Overrides Filters in your main view template and apply it to all views to restore other view properties except for the filters
Message 8 of 11
Demetri.Ingilis
You need to re-read my initial post.
1. I don't want one view template per package with its own filter.
2. I don't want to uncheck filters in my one VT because I am now forced to manually add this package filter to each and every view of each package. I also will then have to manually add all my previous filters that i had applied.
Message 9 of 11
You don't want them but you need them.
Both of these tasks are relatively easy if you know what you are doing: replicate the old filters to new templates and assign a view template to multiple views.
Message 10 of 11
Demetri.Ingilis
I dont want them, because then any small change in one VT has to now be done 9 more times. No thanks.
As I stated in my initial post, I am aware of these two options already, but was asking if the ideal scenario exists. If the answer is no, just say so.
Message 11 of 11
RDAOU
@Demetri.Ingilis
Refer back to reply no. 1.
You could do that with dynamo, NOT with view  filter. At present you cannot combine 4 filters into 1 filter with If statement
