STAIRS WITH CRIPPLED STRINGERS FAMILY
don.perreault
Message 1 of 9
don.perreault
I am trying to Model in Revit Stairs with a Crippled Channel as the Stair Stringer. Does anyone have a Revit Family of a Stair that does this? I have a Stair that frames up to a 3'-0" square landing and the Stringers will be crippled to support the treads and also the 3'-0" square landing.
Replies (8)
Message 2 of 9
RDAOU
@don.perreault
Model the stair without stringer then add the Structural Framing/Beams for stringer >> then use steel modifiers (Cope/Mitter) to Crank/Cripple the Start or End
That's the simple/only guess I can make without any image of the design ..
Message 3 of 9
don.perreault
Thanks, shouldn't I be able to select a C10 member to be a section profile for the Stringer like I saw in a Youtube video. Just not sure how to add a Landing to a single run stair. Right now the only way I can get a landing is to have (2) Stair Runs.
Message 4 of 9
You can draw one run and create the top landing by sketch.
Message 5 of 9
RDAOU
@don.perreault
Sure you can change the profile to C10 or any other which you have loaded in advance
You can have a landing with single run...after drawing the run (Do not finish stair) >>> switch to Landing >> Use Sketch
Message 6 of 9
don.perreault
Thanks, the Landing part I got to work, but the Steel Member size I loaded does not show up as a selection when I click on the Section Profile when I Edit the Stairs
Message 7 of 9
Make sure you load a Profile family, not a Structural Framing family.  And set the profile Usage the profile family to Generic or Stair Support.
Message 8 of 9
RDAOU
@don.perreault
It has to be a profile family (make sure you model it using a profile template)  and you need to change the Profile usage to Stair Support
Message 9 of 9
don.perreault
Perfect. Thanks this worked.
