Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Created drafting view went missing, but exist somewhere...
5 REPLIES 5
Akrie
219 Views, 5 Replies
Hi, I created a cmu detail, and saved the view name as "TYPICAL LEDGER ANGLE DETAILS", and I added to the "CMU Details".  For some reason this detail I created went missing. I can't find anywhere. I did the search on the project browser, but it's nowhere. So today I decided to redraw the whole thing again, and I named the view as exact the same I had, and then I get the message that the name is already in use.
Unfortunately I cannot share the file, but I'd greatly appreciate if someone could suggest the other way to search, or where to maybe look.
Thank you!
5 REPLIES 5
in reply to: Akrie
Browser Organization > Views > All
Akrie
in reply to: ToanDN
Thanks, I already tried it and couldn't find it
in reply to: Akrie
Can you edit the active View scheme and show the Filtering tab?
Akrie
in reply to: Akrie
OMG I had it filtered with discipline structural, and the detail i was looking for showed up after getting rid of the filter!!!!!
THANK YOU!!!!!
Akrie
in reply to: ToanDN
The detail was set to "coordination" discipline! Again, thank you so much, you saved my life!
Forma Design Contest
