Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Continuous reinforcement in an in-plane angled beam
1 REPLY 1
MohammadZaman
115 Views, 1 Reply
Hello
Assume that there is an in-plane angled beam and continuous longitudinal reinforcement is required. How do you place the continuous rebars in that beam with appropriate constraint relative to both the intersecting beams. I have attached a pic showing the issue. Could you please help me to find a solution?
Thank you very much.
1 REPLY 1
suskumar
in reply to: MohammadZaman
Hi zaman
You can do this in Mutiple ways.
1.Create a rebar shape family and place it.
2. freeform rebar will also work, just select the face and give the path.
3. You can also draw by sketching.
In my opinion u can follow first option.
Forma Design Contest
