Show only
Search instead for
Continuous reinforcement in an in-plane angled beam
Hello
Assume that there is an in-plane angled beam and continuous longitudinal reinforcement is required. How do you place the continuous rebars in that beam with appropriate constraint relative to both the intersecting beams. I have attached a pic showing the issue. Could you please help me to find a solution? Thank you very much.
Hi zaman You can do this in Mutiple ways. 1.Create a rebar shape family and place it. 2. freeform rebar will also work, just select the face and give the path. 3. You can also draw by sketching. In my opinion u can follow first option.
