Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Connection deleting notch
6 REPLIES 6
wr.marshall
771 Views, 6 Replies
I have applied a notch to the end of a beam as shown
I then want an angle on the opposite side bolted to both beams. howvere when a apply a connection it deletes the notch as shown
It appears to be this value but it does not allow negative values as shown
Any suggestions welcome
Labels (2)
6 REPLIES 6
RPTHOMAS108
in reply to: wr.marshall
If you use the right connection doesn't it notch the beam automatically (as part of that), with existing notch doesn't it just get confused? How does it know what you have there originally? Perhaps it does but that would seem like a lot of permutations to consider.
Clip angleClip angle
That dimension can't be negative I assume because it would imply a clash in horizontal (less than no gap), whereas vertical can because it can extend beyond top, perhaps.
wr.marshall
@RPTHOMAS108  what connection did you use there ?
RPTHOMAS108
It is just called clip angle:
You can also reverse it similar to how you have it:
Is a bit of an old connection type in UK, would tend to use fin plates welded into the web of other beam (for web of incoming beam to connect to with bolts) nowadays.
More welds in factory, less bolts on site, also stiffens web at point of connection.
RPTHOMAS108
in reply to: ToanDN
You don't need to cope it, you can just place the connection.
All the notching parameters are defined within. A single connection entity with a single calculation for it (in the future perhaps).
in reply to: RPTHOMAS108
You are correct.
Forma Design Contest
