Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
CONCRETE BRIDGE MODELING
7 REPLIES 7
Message 1 of 8
2070 Views, 7 Replies
how could i model a concrete bridge via Revit 2019/2018?
7 REPLIES 7
Message 2 of 8
Luiscko
I recomend you create a diferents types of families that you have in your library like the precast column and beam if is made of concrete or creat a 3 plates and custom families if is made of steel.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
Message 3 of 8
It really depends on the design of the bridge.  Can you show how it would look?
Message 4 of 8
in reply to: ToanDN
YES
Message 5 of 8
You can use Structural Precast Columns, Beams, and Floors.
Message 6 of 8
ovidiu_paunescu
You can also use Infraworks, which has a multitude of parametric bridges and components available. Those can be customized according to your requirements.
The resulting bridge can be imported to Revit for detailing.
Other than that, you can model it directly in Revit by creating all the components (girders, piers, foundations, etc) and assembling them together.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Message 7 of 8
With the use of Dynamo, you can create the Bridge Model
Please find the below links :
https://youtu.be/hO7kpIaslx4
https://www.youtube.com/watch?v=YNKOTGO_va4&list=PLMPk1RvtjI0fSJRCiv8-FrAFNY4Uzc5Js
Message 8 of 8
jc3000
También hay un aplicativo para la generación de puentes en voladizos sucesivos
https://youtu.be/JPeURw0kpVE
Forma Design Contest
