Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Column location is incorrect
4 REPLIES 4
ArmanMargaryan
718 Views, 4 Replies
Hello!
There is a problem installing the columns. When I insert the grids, then insert the column, the location is correct (See picture: true), when I move the grid, the location is incorrect (See picture: wrong). What is the problem?
Sorry, if I could not explain the problem well.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
Tags (2)
Labels (2)
4 REPLIES 4
hmunsell
in reply to: ArmanMargaryan
are the columns being placed from the same view? can you upload an example file to us to look at?
Howard Munsell
ArmanMargaryan
in reply to: hmunsell
The problem has already been solved, thank you.
Arman Margaryan
Linkedin | Facebook
hmunsell
for those who may be having similar issues, what was the solution?
Howard Munsell
ArmanMargaryan
The problem depended on the 3D և 2D state of the grid. When the grid was in 2D, the column didn't "understand" the connection to the grid.
Thank you so much.
Arman Margaryan
Linkedin | Facebook
