Column location is incorrect
ArmanMargaryan
ArmanMargaryan
Hello!
There is a problem installing the columns. When I insert the grids, then insert the column, the location is correct (See picture: true), when I move the grid, the location is incorrect (See picture: wrong). What is the problem?
Sorry, if I could not explain the problem well.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
hmunsell
are the columns being placed from the same view? can you upload an example file to us to look at?
Howard Munsell
ArmanMargaryan
The problem has already been solved, thank you.
Arman Margaryan
Linkedin | Facebook
hmunsell
for those who may be having similar issues, what was the solution?
Howard Munsell
ArmanMargaryan
The problem depended on the 3D և 2D state of the grid. When the grid was in 2D, the column didn't "understand" the connection to the grid.
Thank you so much.
Arman Margaryan
Linkedin | Facebook
