Co-ordinates Extraction
Hi all,
             Is there any way to extrac the co-ordinate values to excel from revit file like autocad. I have a little knowledge in Revit.
Pls help
STM
RPTHOMAS108
Not directly i.e. you can't schedule them.
You can use either the RevitAPI (macro/Addin) or Dynamo. Depends what category of object also there are generally two forms of location: LocationPoint, LocationCurve.
If you are looking at structural columns for instance then these are level based (where the Z of LocationPoint is not relevant). So you take X,Y from location point and then consider Z for Level elevation and offset from level (parameter values).
