I have a large view that is split into two separate views (as dependent views) to fit on sheets. I also have slabs that cross the split line and are shared between the two dependent views. When I use the Span Direction Symbol family to tag the slab, the tag shows up on the parent view but not the dependent views because the extents of the slab go beyond the dependent view. Is there a way to get this tag to show up on the dependent views even though the entire slab is not visible?
