02:30 AM
Hi!
I’m working with the integration between Revit and Robot. I am wondering if it is possible the change the geometry to a floor without changing the position of the analytical lines?
Example:
You can change the geometric position to a beam without changing the analytical lines.
Can you do the same with a floor or a wall? Can you change the areal without changing position of the analytical lines?
