Change geometry to floor without change the position to the analytical lines
Hi!
I’m working with the integration between Revit and Robot. I am wondering if it is possible the change the geometry to a floor without changing the position of the analytical lines?
Example:
You can change the geometric position to a beam without changing the analytical lines.
Can you do the same with a floor or a wall? Can you change the areal without changing position of the analytical lines?
A_MAQ
why do you want to do that ?
Autodesk Expert Elite
MostafaElashmawy
There are many ways where you can control the analytical model interdependently from the floor.
1- Z direction.
2- Slab edges
3- Analytical Adjust (Openings).
4- Analytical Adjust (Points).
Please follow attached screencast.
Mostafa Elashmawy
