Beam Systems - Can Shared Parameters Act Like Worksets?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hiya All,
I'm trying to control visibility of Beam Systems, AND the individual Beams within the system, all with one Shared Parameter in our projects. We already use a shared parameter to hide walls and posts coming down from above if they're not important for the framing level we're working with, but some beam systems need to be hidden/filtered out as well, and when I apply the Shared Parameter to the Beam System, it hides the beam system, but all joists in the system don't have the parameter so I have to select all those and add the parameter to them as well.
I know this works with Worksets, where a Beam System gets assigned to a workset, and then all the beams inside the system also get that assignment, so view filters on worksets work well, but that means the project needs to be workshared and different project managers have different opinions on whether a project should be workshared or not. So it would be nice to find a way to get a shared parameter to work like Workset assignments.
See Below for a picture of what I'm looking for - I have a Shared Parameter on a whole bunch of framing family types, Level, and I can assign it to the beam system, but it doesn't pass that assignment to the beams inside the system like a Workset would.
Probably there's no fix for this but I figured I'd ask in case anyone else does this/has done this.
