Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Baseplate
2 REPLIES 2
ANLVerhoevenBouw
831 Views, 2 Replies
Baseplate
Hello everyone,
Can somebody please help me with the following:
I am trying to make a parametric template plate for placing anchors on construction site. This plate is made out of steel.
So my variables are:
length and with base plate
n holes side x,
holes side y,
radius holes,
I have tried to make a nested, face based void family, but it'll constantly lose its host, because I am cutting at the edges:
This is the error I am receiving when I am using a face based void family which already created.
Can somebody help me with a solution.
Regards, Mark
Labels (1)
2 REPLIES 2
in reply to: ANLVerhoevenBouw
Have you tried a semi-circle the full circle void?
ANLVerhoevenBouw
in reply to: ToanDN
Usually the steel plate function with holes is ok for me, but I'd like to work with a family so it keeps customable troughout the whole project.
Actually i've been working for a work-around with nested family's.
So I made a face based void en continued to make face based array of that void. When I am nesting that array in the steel plate the host will stay my steel plate. One of the non variables is that on every corner I have a quarter cirkle void, the number in between is variable, so n has a minimum of two. But when both of the arrays (horizontal and vertical) have n=2 the second array hasn't anything to cut so it'll give an error.
The next problem is that I want to cut a variable number in the steel plate. So in type 1, I need an number one cut out. In type 2 I need a two to be cut out. Maybe there is something as a conditional void or something like that?
Please take a look in my family
Greet Mark
Forma Design Contest
