Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Can I automatically produce plans & elevations with changeable parameters
1 REPLY 1
RCEngineers1
130 Views, 1 Reply
I was just wondering if there is a way to create structural plans & elevations automatically by inputting data. For example, is there a way to just input length, width and height and the number of columns/posts along with purlins and girts and then Revit automatically produce a set of drawings.
I have attached screenshots below of the outcome we want. It will be a basic rectangular structural frame however the size and number of bays will change from job to job. If there was a way to speed up the process of producing a set of drawings that would be a huge help.
RCEngineers1_1-1668631787094.pngRCEngineers1_2-1668631795509.pngRCEngineers1_3-1668631808010.pngRCEngineers1_4-1668631821273.png
1 REPLY 1
in reply to: RCEngineers1
Create one model and associate dimensions with global parameters.  When you change those global parameters,  the dimensions change and drive the model change.
Forma Design Contest
