Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
adding unprintable structural column dimensions on plan
2 REPLIES 2
jc.methot
341 Views, 2 Replies
an engineer with whom I work wantsme to add column dimensions on plan beside structural column.
I wonder if there is a quick way to modify a column family to achieve such thing.
2 REPLIES 2
ArmanMargaryan
in reply to: jc.methot
I do not understand your question well, can you post a sketch?
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
hmunsell
so your coworker wants to see the dimensions of the columns on the plans, but you don't want them printed? is that correct?
Revit does not have "Don't Print" option like AutoCAD dose in the layer settings.  however, dimensions are View Specific so you can duplicate your view and add dimensions to that view. when your coworker wants to see the column dimensions, they can look at the view that has them displayed.
A lot of companies have adopted a Working and Documentation view work flow.
  • Working views are views you can add extra information that you don't want to see on a sheet.
  • Documentation view is a standardized view, usually with a View Template, that is what gets placed on a sheet.
Howard Munsell
Forma Design Contest
Technology Administrators
