Zone color schemes in ceiling view?
Message 1 of 13
Is it possible to  see the color schemes that you have for zones in a ceiling view?  For example, if I have a couple spaces in a building seperated in zones  and I want to add mechanical equipment and diffusers to the ceiling plan for each floor; it would be easier to do it if I could see the zone colors.  It would avoid me having to keep going to the floor plan to see the zones.
Replies (12)
Message 2 of 13
CoreyDaun
Nope - Color Schemes are not available for Reflected Ceiling Plan Views. A work-around would be to create a Floor Plans specifically to show the Color Scheme, and then place that View and the RCP View on a Sheet View, on top of each other. Work through the RCP Viewport via the "Activate View" command from the right-click menu.
Message 3 of 13
Is there a legitimate reason why revit can not have a color scheme on a reflected ceiling plan?
Message 4 of 13
RobDraw
Of course there is.
Rob
Message 5 of 13
tlagardeAJBTA
I can't find a constructive way to answer that, has this feature been officialy requested ? I suppose not, I'll give it a try
Message 6 of 13
curtisridenour
Message 7 of 13
tlagardeAJBTA
Got it, just upvoted
Message 8 of 13
iainsavage
Don't wait for it to happen though - it probably never will so meantime you'll need to use @CoreyDaun 's workaround.
Message 9 of 13
tlagardeAJBTA
Remember Justin Bieber, never say never
Message 10 of 13
iainsavage
There are requests from 2007 which have "not yet" (if you don't like never) been implemented.
There are nearly 48000 posts on the Ideas forum and some 382 have actually been implemented so whilst "never" may not be accurate you might be retired or dead before it happens.
Meanwhile use a workaround if you want to actually output any work product (at least that would be my best advice).
Message 11 of 13
curtisridenour
that is the sad truth. poor one out for the Revit users we lost along the way waiting for ideas to get implemented.
Message 12 of 13
HVAC-Novice
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 13 of 13
iainsavage
