Revit MEP Forum
waste water treatment in Revit MEP
2 REPLIES 2
422 Views, 2 Replies
Hi Everyone, i am a Revit MEP Modeler and have recently picked interest in waste water treatment. where does one get families for this discipline? i have tried autodesk Seek, Revit City and got nothing...Please help!! any one willing to share some sample layouts for information purposes?
2 REPLIES 2
pkolarik
All I can say is:  Good luck.
Enough of the OOTB fittings are inaccurate that you really need to check over them all. Alot of the content (fittings) that I've found so far from manufacturers either is very old and needs updating for the way Revit works now or wasn't really set up all that well in the first place as far as I can tell. (take this all with a grain of salt;  I'm working through my second Revit MEP WWTF project, and our department only got Revit in October)
For fittings, most of what I've added to the OOTB stuff is stuff either I have created based on an existing fitting, or our reseller has created for me/ helped me out with.
As for pumps and pieces of equipment.... about 80% or so of our suppliers are able and willing to provide .stp files of their equipment for our use. (the other 20% I've simply modeled in autocad and imported into Revit)
CADmonkey_UK_Building_Services
Hi! One builds them oneself!
Find some technical literature for a Plant item and get busy.
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
Forma Design Contest
