vertical dimension to 3D
How to insert a vertical dimension to 3d view?
www.TechRoom.bg
i think this post is not for plumbing sections 🙂
You can dimension Revit constructions also in 3D views, horizontal dimensions can be inserted as easy as in plan views.
There is a small problem when you decide to add vertical dimensions in this 3D view - e.g. wall heights. This is caused by the reference plane being set by default to the horizontal position/orientation.
But you can just use the Architecture ribbon and the Work Plane tab to start the Set Work Plane tool.
A dialog box for setting a work plane will be launched.
Select the second option - Pick a plane and choose any vertical edge in your model, in this case a wall edge.
After you have set a new work plane this way, you can now insert also vertical dimensions to your 3D view.
I hope this will help you!
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
Ah sorry its my fail . I was clicked on wrong section.
Thank you for fast answer its help me a lot.
