Revit MEP Forum
v/g of grid lines in linked files
2 REPLIES 2
julielfifield
1361 Views, 2 Replies
How do I turn off the grid lines in my linked files? I have 3 sets of grid lines showing now.
2 REPLIES 2
arqyt
in reply to: julielfifield
Hello, I use 2 options I explain you:
1- Coordinate between files matching items, such as grids and levels. This through options Collaborate/Copy/Monitor.  It vision is not controlled, they are identical and thus matching.
2- Check the viewing mode through view templates o v/g as you like. Imported always through options Revit Links. Creating a concrete view in each file from which concrete objects view, details view... want to see, or custom specifying the visible categories.
It's a bit long to explain but intuitive.
Hope that helps
A greeting
Jose M Carralero.
ArqyT
You can try this:
Go to v/g overrides -> Revit links -> Display Settings -> click Custom -> Now you are in linked file v/g overrides -> click to annotation category (check custom view) -> scrool down and uncheck grids.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
Forma Design Contest
